Technical Transmission warning red
2010rachel29
Hi can any one give idea what's best to check first?
Already checked battery and is fine.
Also any easier option to top up transmission fluid?
Location of top up ?
Different videos online seem to suggest different methods. Had saw Turkish using a funnel with long model but can seem to find video now to double check details.
Car driving ok not stuck in gear , changing gears as normal.
500l now 1.3 multijet automatic diesel 2014
Also prior to this reverse light warning came on but has gone off now not sure if this has any baring.
Thanks for that. If fluid levels seems ok would you have any other suggestions to check as everything else law seems to be working fin , oil, coolant all done filters etc changed in September and no actual mechanical issues showing as of yet?
