Yep. Mind you, it's only about 20 minutes work on a Mk 1. Jack (with block of wood) under wishbone, just keeping wheel off ground, and you should be able to turn the mount round without removing the strut.
Pretty much have, I'd say. We've not fully explained the effect of cator on handling, or even dipped into the relationship between castor and camber, but we're not wtiting a book on susspension, init?Fiat put the castor mod there for a reason. We have not fully explained that.
More, I think, that the front has more components and more potential for play.Also putting a backled wheel to the rear causes less or no vibrations which is an indication that castor does have an effect.
On a front wheel drive car you need negative castor on overrun and positive castor when power is applied to the wheels; think about pushing your sofa around the room; the castor wheels will swivel so the the axis of rotation of the wheel is behind is behind the swivel pin; then imagine the wheel has power applied and turns of it's own accord; the castor will swivel so that the wheel is now in front of the swivel pin.
But this is clearly untrue! Just look at the fookin suspension from the side with the wheel and arch cover removed, it's clearly inclined backwards.Most FWD cars are set to have zero castor angle for this reason.
On the punto the top of suspension unit (actually the top of the shock absorber/damper on a Macpherson strut) can rock fore and aft to allow for these differing requirements. .
Punto is not a performance car so it must be a simple reason why Fiat make the castor change possible. Unfortunatelly you do not know why.Pretty much have, I'd say. We've not fully explained the effect of cator on handling, or even dipped into the relationship between castor and camber, but we're not wtiting a book on susspension, init?
What stops me to get all that advantages with my manual steering by moving the top castor setting to the power steering position?Because you can! Quick racks, less unwanted camber change, are all good things. You can only have them with power steering. If you're fitting power steering because Joe Public is getting fat, lazy and stupid, you may as well have the advantages.
You assuming that the castor increases and the steering will them become unbearable.
Working out "how come" is beyond my current knowledge. All I can tell you is that it does.You do not believe that do you!! You already said that the steering is light on manual steering MK1 on another post, how come a small castor angle change make that much of a difference?
Also higher castor angle actually increase camber when the wheel is turning is that an unwanted camber change that you mentioned earlier in this post? The fact is that you do not really know why Fiat done it,
fingers99;3126501 Unbeareable is unquantifiable said:The thing is the manual steering is no where near as heavy as PAS as there are more turns. The manual steering is not a quick rack. This means that it will be certainly bearable to drive. And if the PAS castor setting gives better handling caracteristics this will be certainly worth a try.
