Hi.
I'm on my 3rd new Doblo van - 2003/2011/2023 and have come across something I don't understand. I've never had any problems with the previous vans and have fitted tow-bars to them. However, with this new 2023 model I'm struggling. Fitting the actual tow bar was easy - easier than the previous two. I purchased a tow bar electrics kit, read the instructions, understood them and removed the trim and light clusters at the rear. And then came the problem. The looms for both the left and the right rear clusters have a tag on them that clearly says you should not splice into the wires leading to the cluster. I asked around and it was suggested that some modern vehicles have provisions made for tow bar electrics at manufacture as it is easier than retrofitting them. I noticed that on the left side under the side trim there was a unit that looks almost identical to the by-pass relay that came with the kit I purchased. Are the new models already provisioned with tow bar electrics and if so, where do I go from here? The wires from the van relay run forward when I would expect them to run rearwards. I don't want to splice my kit wiring into the van wires for fear or causing damage or a malfunction to the van's electrics. Any help would be appreciated.
rover123mg
rover123mg
