500 Torque settings
500 Torque settings
free labour Steve
Hi all, I'm new to the forum and found it while looking for info on changing the rear shock absorbers and the n/s front lower suspension arm on my step daughters 2010 fiat 500.
Would anybody be able to tell me the torque setting for these?
This might help its a bit dark but you can still read it
Do both arms! trust me,, and its a bumper off job and various cross member/chassis extension removal, also see post #10 here;
https://www.fiatforum.com/500/439332-rear-suspension-bushing-seperation.html
also note front bumper cross member bolts(the big ones) 4 each side only 30/40ftlbs allow a day a side, heat up the two tiny nuts that hold the bumper cross member in place, need to move the washer bottle drivers side, check the condition of the suspension struts too
In that page listing the torque settings - which nut is the one holding the spring on the strut, and which is the one that holds it on the top mount that you access from under the bonnet?
I wonder how they expect people to torque them up? I just assembled 2 struts and I had to get the nut on the top mount "as tight as I can" rather than 65. I had a torque wrench with a hex bit in at the top set to reverse and a ring spanner on the nut. The hex bit simply started deforming the hex hole in the top of the strut the more pressure I put on with the spanner. Twisted the bit slightly too.
Ive not done them on a Panda/500 but the Renault Espace was much the same. I fitted them "tight" and kept watch for any loosening. It was still fine after 10K miles.
If the threads are long enough put a nut on the top to stop the hex expanding.
Tried that on the second one, didn't seem to make a difference unfortunately!
Good idea with the nut..
TBH.. as seen in my panda GUIDE
I did it with spanners and an Allen key
No problems regarding breakages... but it was a chore
I asked for a 'rattle gun' for Chrimbo
And it does a great job..
Its a 18v Dewalt with a 1/4 hex drive
My Screwfix 1/4 hex to 3/8 Sq. Adaptor should be the weak link.. but has shown no issues.
