Alright people, I've just joined but i'm in dire need of advice concerning my '07 Fiat new 500 fitted with the 1.2 8v single cam engine with 28.000km's on the clock.
I decided to renew the timing belt and aux belt because of the years and not mileage.
Unfortunately the water pump is also leaking so i've bought everything needed. Now i've run into problems because I've already dismantled everything but i don't have the timing belt tensioning kit available.
I've timed up no.1 piston to tdc and removed the belt but my engine has a kind of vvt pulley attached to the camshaft sprocket, unlike the punto 1.2's engine that has a fixed pulley.
Basically i'm needing info on how to tension the belt on this version of 1200cc engine, do i have to loosen the sprocket bolt as with the punto or will the timing belt slack be taken up by this 'vvt' mechanism?
Is there a guide available like the excellent punto guide on this forum?
URGENT help required as the car is blocking off my garage!!
And thanks in advance.
