puntoguy22
2014 1.2 punto 69hp petrol model.. fault codes p0101 and p0106 showing up with engine fault light. 11000 miles only on the clock.
The engine seems to run ok then at idle (at a junction say),the revs climb and fall back and the car does not respond to the throttle. If ignition is turned off and then engine is restarted, the throttle responds ok.
Both the MAP sensor and the throttle body inclding position sensor have been replaced but the fault recurs.
Any ideas as I'm stumped!
