You could of done it in the time it's taken you to start this thread![]()
:yeahthat:
If no bleed screws it means the expansion tank is at the highest point on the vehicle, and there for the recirculating water should be returning back to expansion tank and along with any air
Remember when to let the vehicle warm up as much as possible to allow the stat to open up and let the air escape
keeping an eye on the level, dont let it drop too low
How ever a self bleeder should never make rushing water noise, it means an air lock or a leak
Ziggy
Gotta drain the system first haven't I? Got red to go in and PO has used blue. Question is I'm ok using it for now aren't I?
The punto has them. Landie doesn't even have an expansion tank.
What Landy you got![]()
Series III 2.25D
