Hi all,
Got a look under the car and it appears that it is the exsaust.
Problem1, the rear center box mounting is for some reason scrapping the underside of the car? so im gonna have to either cut part of the mount or fix problem 2 and see if that helps.
Problem 2 the rear exsaust mount is torn, cracked and in need of replacment This is also causing the exsaust to move more than normal which may be causing problem1 to be a problem
However, i cannot seem to find this rubber mounting replacement part. EuroCarParts do not sell it & Halfords don't either. its a trpeziem shape (soz about spelling - its a 4 sided shape where top & bottom side are differnt sizes while the other two are the same size) There appears to be 7 or 8 holes in it.
Does anyone know where to get one from?
(Mk1 1997 fiat punto 55 s 1.1L 3door)
