The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Hi everyone. I am new to the forum and have a little favour to ask about the radio codes. It is for a new Ducato camper that had the radio swapped. I see that there is a donation to be made and that is fine.
the details on the side are:
A2C81465001
2017/10
348-037-203
Sorry..... I don't have codes for Continental brand radios.
You will probably have to get it from a Fiat dealer, or a car radio workshop.
Re: code for fiat punto please
Hello my serial number is BP137123153169
And my product number is
Fiat Palio CC
7 641 371 316
Can you please help me?
Fiat Palio CC
7 641 371 316
I have the code for your radio.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
Hello. I need the code for my radio please.
BP873091797135
7648730516
Many thanks burger1958
Thanks for donating to the forum. (y)
I've not seen part number 7648730516 used for a Fiat radio before.
If it uses the same calculation method as other Fiat Blaupunkt radios, your code should be: 1521
Please post back to let me know if it works or not.
Hello friends,
Can someone help me with the code for this radio?
(P)1RZ26JW4AF
TxxYD146110725
6763M111460725
Celso
BP873091797135
7648730516
Hello I think I have given the wrong number it is
7354949830
Strange mistake to make, the numbers are completely different. :confused:
The serial number you originally posted ( BP873091797135 ) does not match the new part number ( 7354949830 ).
Post the correct part number, and serial number, and what car the radio is from.
Ok this is all of the information on the radio.
Bp-nr 7648730516
905 this number goes just before the BP
Bp873091797135
Fiat-7354949830
Fiat 189 cd panda
Hope you can understand them.
Bp-nr 7648730516
Bp873091797135
Fiat-7354949830
Fiat 189 cd panda
Serial number BP873091797135 matches part number 7648730516, so unless the calculation method has changed, the code should still be 1521
Hi folks
Want to swap the broken radio/cassette player in my Stilo for a second hand radio/cd player and wondered if anyone could provide me the code - serial number for the replacement (i think!) is M189944 and part no. 735374218. Cheers.
Hi
Can anyone confirm - when i have entered the 4 digit security code is there something else i need to do to activate the radio/cd player ie press another button or something? Asking because when i put in the code, this is displayed on the unit but nothing else then happens.
Cheers.
Had a look around on here - says button 5 (rpt) is the code accept button, but when i enter the code and press 5 the display says to wait a certain number of minutes (goes up one minute each time? - up to four minutes already), as if it's the wrong code.....? Any ideas?
