rattle & squeek said:
Fiat Tempra 1600 1997.
Yesterday I removed all the relays in the fuse board and bingo moisture, the wiring running down from under the dash to the fuse board was also damp, I removed and dried all the relays with a hair dryer but have not removed the fuse board.
I have sprayed all wiring and electrical componants with contact spray and now everything seems to be working alright, only the central locking is intermittent but this could be something to do with moisture in the left door as the door switch lights are not iluminated and the window is wet when I raise it.
The car is running better and the headlights are brighter. The car started playing up on the evening of a torrential downpour so I am sure the problems stemmed from what you suggested.
Electrics on Fiats and water have always been a problem.
I forgot to ask does the car have a sun roof ?
This is another potential water source as the drains from the sunroof mecahnisim get blocked. Open the sunroof fully and (from outside) in the front corners you will find a small hole, blow it through with an air line, it's usually bits of leaves but occasionally spiders can nest in the pipes - not a wind up, i've seen it. Rarely the drain pipes come off the sunroof housing they need putting back on with a jubilee clip but for that you have to remove the headlining. The mechanisim has four drains, its the front two that seem to be the main problem, each drain connects to the corners of the pan that the sunroof sits in and pipes drain down the windscreed pillars at the front, in an estate, down the pillars for the 5th door, in a saloon, don't know never had one but must be down the rear window pillars into the boot.
In the long run it will be worth removing the fusebox to dry it out by slow heating, if you can put some plastic over the tope of the fuse board to shield it from the dripping, some models of Tipos and Tempras has just this, plastic cover over the fuse board, Fiat had obviusely had the problem.
The central locking will probably be the last to work it does seem to be the most sensitive, the wiper delay can also suffer when water is about. Also check the relays themselves, I've had a couple with water inside the relay after draining through the fusebox.
Make sure you find the source of the leak, don't want to go through this again. For water in the doors look along the bottom edge of the door there should be three small slits, they can get blocked from road dirt.
