General Temp Sender help please.
Mufflaz2005
lincoln
Hey got a 1.1 8v 55s punto & added some sporting clocks to it but I need a temp sender for it as standard clocks one is different (black end) any idea where I can buy a brand new one from because I'm not really up for getting a second hand one from scrappy as there cheap enough brand new I heard, many thanks Alex
I just did this today, buy one for a punto sx from eurocarparts.. under a fiver,
the part number is 224650010
You need a larger spanner to remove the old and smaller to install the new.
Btw what did you use to make the rev counter connection behind the dash? I just ripped apart an old ISO connector and used the clamp spade connector and slid it over the copper strip on the dials, the fed the wire through the fiat block connector.
