Hi there, I may need to remove the front wing off a 2008 diesel Panda and what I would like to know please, is do the front wings bolt on or are they welded on?
Bolted and glued in place. Need to remove the bolts and then yank off while trying to cut through the glue at the same time with a knife etc. Bit of hard work will sort it, although your wings won't be reusable after as will normally deform.
Why do you need to remove your wing out of interest, is it damaged and needing to be replaced
