Technical Suspension
Tywysog
I am thinking of fitting either coil overs (my preference) or new shocks and springs to my B. However, I do not want to lower the ride height. Any suggestions? Thanks
If you have the funds, go for something along the lines of Bilstein B8's or Koni Sport dampers. Then just find yourself some OEM springs, what puts you off lowering?
Hi, not keen on lowering due to some mountainous speed bumps in the area, also poor state of local roads.
Ah, then you need to bear in mind most sport dampers will be slightly stiffer than standard dampers, some allow you to fine tune them to get optimal handling/comfort.
