General Suspension swap Grande Punto 2008 with Punto of similar age
Masterbond7
Waikato
Due to the state of the local roads (not good) I was thinking about swapping my car's front suspension (2008 fiat grande punto) with some suspension springs from a similar age punto in the hope that it will make the ride a bit softer.
Would this work and what problems do you think I might run into, additionally would it be ok to keep the rear suspension as is, or would I need to swap it out too?
Thanks,
James
Thanks,
James
I have a 1.3 diesel and an 875cc 2 cyl
The dampers and springs are different..different to the 1.2/1.4 FIRE also
The top turret : inner wing will be identical
The bottom fitting..2 bolts onto the hub will PROBABLY be the same too
You have the options of :
New Dampers
New Springs
Different spec of spring
New components... Droplinks.. cheap and easy :)
Wishbones..a lot more involved
Are you experiencing a Crashy ride?
Yeah, I am experiencing quite a harsh ride. I'll make sure to check the sizes and dimensions on the donor vehicle beforehand, thanks.
