General Sun visor
General Sun visor
Desmo
Forfar, United Kingdom.
The driver side sun visor on my wife 2012 Mk3 Panda has gone floppy and keeps falling down. The there is a spring clip sort of thing inside it which has broken. I've done a bodge to it which at least stops it falling down but it really needs replacing. There a few from Mk2 Pandas on eBay but none for a Mk3 although they look very similar. Can anyone tell me if theMk2 sun visors are the same as the Mk3s?
The only ones I know are the
500 which fit but they are smaller
I doubt anyone has tried every combination
For example the trim changed slightly on the Panda in 2009
The 500 has also undergone some changes but I doubt any fitments on the visor has changed
check the year as what you call a mk3 may also be called a mk2 as they were originally on this forum, confused the heck out of me when my 2009 Panda suddenly became known as a Mk3 here but still a MK2 for parts etc!
It is a 2012 model but definitely a Mk3 with the later style headlamps although I've had problems getting the correct drop links and track rod ends. The body code is 312PXA1A P0
EDIT : According to Wikipedia it's a Mk4!
Yep later more rounded body
MK4
On this forum
Parts suppliers could be labeled as anything
169 and 319 is far less confusing for everyone
