I am looking for advice. My selespeed pump is as what i think working a bit more than it should. When cat is in neutral, and working in place, my pump is working every 7.5 - 7.6 seconds. I know most people would say it is you accumulator not holding presure, but when I took it for the spin my lowest bar/pressure was at 40. If I am correct, and if my accumulator was not holding pressure I would see bigger oscillations in hydraulic pressure. Is that correct?
I do have sudden spike but that must be glitch otherwise if it was correct with that pressure all parts and pipes would fall apart.
I dont have any problems changing gears, everything is working as normal.
Here is my data. Car was idling.
Do I have to do some adjustments?
This is my data when I took it for the spin. You can see when pump works again. Could this be possible that it is leaking pressure somewhere?
https://docs.google.com/file/d/0BzgdK6BxpnTBWnpiQmNUckstaHc/edit?usp=sharing
