- Joined
- Oct 21, 2019
- Messages
- 13
- Points
- 81
Hi All
I've been tidying up my 2004 1.2 Panda since purchase having brought it for my daily commute and also as the 'learner' car for my daughter.
The starter motor failed a few weeks back, I knew it was failing but unsurprisingly did nothing until it totally failed one morning leaving the poor chap stranded on my sloping drive.
I got a decent replacement from my local supplier and went into battle to fit it, I much more fiddly job than I had hoped for and one that exposed the Haynes manual for the useless investment it was !
When I removed the electrical connectors from the old motor prior to pulling it out I noticed a thin spring washer behind the ignition connection, it was corroded and in 2 pieces, my local supplier didn't have one and suggested only a main dealer would have then, I needed the car fixed so carefully soldered the washer back together, I assumed it carried little current and all was well once the whole thing was back together.
It's been about a months and all was fine until the last week when I've started to have problems starting the car, I turn the key and nothing happens I repeat the process a number of times and eventually it starts as normal, the battery is fairly new and I've double checked the terminals.
I suspect this washer may have something to do with it along with the repeated restarts it's been going through every Sunday with our learner driver !
Anyone had a similar issue or know the part number or a suitable replacement for the spring washer, I'm not looking forward to having to remove that starter motor again :bang:
