Complete a level in original sonic.
Hold right on D-pad and press A at a couple key moments.
Complete level in Mario.
Navigate your character to the right until you come to a question mark |
| block with a goomba hanging around it. Hit the question mark block, and |
| stomp on the goomba. Look right and you should see three more question |
| mark blocks. The leftmost question mark block contains a power mushroom |
| which I recommend grabbing. You can get the two other question mark |
| blocks if you choose; they are only coins. Now, head right until you |
| jump over three pipes and find two goombas wandering around. Stomp on |
| the goombas heads. The pipe to your right is a warp pipe; you can go |
| down it if you choose to, however, I don't recommend it. Head right over|
| the pipe, and you'll see a green hill in the background. Stand so that |
| your back is covering the left side of the green hill, and jump. You |
| should hit an invisible question mark block, and a 1-up mushroom should |
| pop out. Grab the 1-up mushroom before it falls off the edge. Now, jump |
| over the pit to your right; you should see three blocks, the middle one |
| being a question mark block. Two goombas should fall on the blocks, bash|
| them before getting the question mark block. Now, get the question mark |
| block; it is a power up. Now head right and jump over the pit. You |
| should see two goombas, bash them as soon as you can. The lone block |
| above you is a multi-coin block, repeadidly hit it as fast as you can; |
| the faster you hit it, the more coins you'll get. Now head right and you|
| will come in contact with the first koopa troopa of the game. Kill it by|
| jumping on his head, and kicking his shell. A little bit to the right |
| you should see two blocks, the rightmost block contains a starman. Hit |
| the block and grab the starman which will give you temporary |
| invincibility. To the right of the starman, you'll see four question |
| mark blocks. The highest up block contains a powerup, and the three |
| lower blocks contain coins. I recommend getting all four question mark |
| blocks. Now, head right some more and you should see six more goombas |
| that are walking in pairs of two. Stomp all of them, or kill them with |
| star power if you still have it. You should see two question mark blocks|
| that are elevated high in the air. You'll need to jump on the blocks if |
| you want to get them. They both contain coins. Head right some more |
| until you get to the gap in between the third and fourth set of steps. |
| Jump over this gap, and keep heading right. You should see a pipe, which|
| is the pipe that you would have exited from if you chose to go down the |
| pipe at the beginning of the level. To the right of this pipe is four |
| blocks and two goombas. Kill the goombas by bashing their heads, and |
| hit the question mark block, which is a coin. Now head right past a pipe|
| to a larger staircase made out of blocks. Climb up the staircase and |
| touch the flagpole to finish 1-1.
Sonic wasn't even a real game. It was a colour show to put toddlers infront of too stare at.
