Hello my dear friends and barchetta lovers. I would like to ask for some help and advice. There are few issues with my little silver B and I would like to deal with them now during the cold weather so the B will be perfect in the spring
1st: My barchetta is doing high intense whistle noise after startup. No matter if it is hot or cold outside, it always do that for few seconds (maybe 5 - 10 sec). It is also changing the rpm a little bit and the noise is a little bit louder when the rpm are higher. I replaced the angular belt, as I have a feeling that the noise come out from that part of engine, but it did not help. Any suggestions?
2nd: The engine itself has a strange knocking noise. It is not a variator, I changed it because of the diesel sound. The barchetta was running very nice but after a short trip it started to do the clapping noise and now it just does not sound very nice.
3rd: With the bad noise comes bad power. I have a feeling like myB is running on the 1/2 - 3/4 of its actual power. I guess it has something to do with the problem with sound (?) Also it eats more fuel. The air sonde is ok I guess, I have it cleaned with the cleaning spray and it looks allright.
4th: During the wet weather is the B doing some strange noise from the back. It is like it is coming from the wheel/suspension but during the dry weather it is ok.
5th: the barchetta is kinda unconfortable and terribly noisy. I was driving another one and it is like two times more comfortable than mine and far less noisy. The car does not feel so solid and after driving over any "hole" in the road it sounds like a piece of crap. Even with the roof down. The worst nightmare comes with hardtop on. Every noise if more louder. Changet the window fittment, so the sound from the outside is almost minimal, but the inner sounds are really strong.
6th: changing the oil in gearbox. Is it really neccesary? The car has 150k km I have it for about 20k. I dont know when the oil was changed and I did not changed it yet.
7: I have problems with starting up the engine. I thought it was because of the battery, so I charged it, but barchetta starts a little harder. It is always on the first attempt, but not so nice and quick as it used to.
8: My key started to do some problems. I have the key + code light very often and I have to remove the key and insert it again to be able tostart the car.
Thank you all for answers and help!
