Tell us this codeHi all, 2.0 Scudo Mjet 2011 in limp again showing code for fuel temperature sensor however the van doesn't have one. Any ideas?
Good call lol. Its po183 thanksTell us this code
Rightio, im looking in the wrong place then. I thought it would have been in the injector pump or rail. ThanksThat sounds like a sensible code..
When I had that on a punto diesel I had to change the sensor at the fuel filter..
it did fuel temperature AND water in fuel..same sensor
Argh Im even more confused now the deeper i get into it. The filter housing is a 2 wire connector so if this sensor is a water in fuel and fuel temp sensor how would it do both? Checked the voltage at the connection and i get 12v ign on and earth. I feel im missing something.Rightio, im looking in the wrong place then. I thought it would have been in the injector pump or rail. Thanks
Thanks for help, my sparky mates coming soon ill update later.Have you checked the integrity of the earth and power at the sensor. Apply a small load with a test light on each. A dvom can mislead you.
Ok progress being made. Found the temp sensor its under the air inlet manifold on the return fuel pipes. Tested the sensor and resistance and it drops as temp rises and vice versa. Unplug sensor and its Its getting 5v until its plugged back in then voltage drops to 1.9v does this mean sensor is goosed?Have you checked the integrity of the earth and power at the sensor. Apply a small load with a test light on each. A dvom can mislead you.
If I'm not mistaken the 1.9v is variable as the resistance of the sensor changes with temperature. So the ECU uses the 1.9v to see the temperature. The 5v reference voltage is perfect, you have proven the changing resistance with temp change, you could belt and brace by measuring the 1.9v change as temp changes.Ok progress being made. Found the temp sensor its under the air inlet manifold on the return fuel pipes. Tested the sensor and resistance and it drops as temp rises and vice versa. Unplug sensor and its Its getting 5v until its plugged back in then voltage drops to 1.9v does this mean sensor is goosed?
You need to prove the wire integrity at the ECU. Measure the 1.9v at the ECU plug (back probed).
Your sensor looks good.
Yes i think thats the way to go, trace back to ecu. I presume wires will be the same colour? Hope so.If I'm not mistaken the 1.9v is variable as the resistance of the sensor changes with temperature. So the ECU uses the 1.9v to see the temperature. The 5v reference voltage is perfect, you have proven the changing resistance with temp change, you could belt and brace by measuring the 1.9v change as temp changes.
Hi yes i used Lexia Peugeot diagnostics and fuel temp is a constant 90 degree so something defo adrift. I have 5v at the sensor like u said and a varied resistance as pressure changes. So its leading me to a problem inside the ecu. Ill give it a few more hours of my life then thats it lol.You could also do a scanner live data and see the actual reading the ECU is seeing and do your temp test again. Job done.
Okay,Hi yes i used Lexia Peugeot diagnostics and fuel temp is a constant 90 degree so something defo adrift. I have 5v at the sensor like u said and a varied resistance as pressure changes. So its leading me to a problem inside the ecu. Ill give it a few more hours of my life then thats it lol.
PsHi yes i used Lexia Peugeot diagnostics and fuel temp is a constant 90 degree so something defo adrift. I have 5v at the sensor like u said and a varied resistance as pressure changes. So its leading me to a problem inside the ecu. Ill give it a few more hours of my life then thats it lol.
My apologies for the confusion, at the sensor if it's a 3 wire sensor ,1 is 5v reference power supply and 1 is ground to chassis the 3rd is the signal wire to ecu. As the pressure changes the sensor resistance should change and the output signal voltage to the ecu will change accordingly. This voltage should be exactly the same at the ecu. Ie the 1.9v in the other thread.Hi yes i used Lexia Peugeot diagnostics and fuel temp is a constant 90 degree so something defo adrift. I have 5v at the sensor like u said and a varied resistance as pressure changes. So its leading me to a problem inside the ecu. Ill give it a few more hours of my life then thats it lol.
