Hi there!
I recently bought an 'S' reg Sciento sporting as a project. Main problem is it doesnt start. it had been stood for 4 months and when the previous owner tried to start it it wouldnt. i have swapped most of the sensors, coil packs even the injector from a scrap punto but it still doesnt start. i cant get my head round it... timing is right, compression is good, fuel pump works, good spark at the plugs. i've reached a hurdle at the ecu. could this be the problem? if i turn the ignition on and off about 5 times i can get it to fire sometimes. not very often but once its running it runs fine! took it for a drive and it is great! when you try to start it from 1 turn of the ignition it tries to fire, just the spark seems to late. almost like the it is retarded too much?????? i do not have the red key. looking at other forum q's i dont think this is the problem... just givin you a heads up on the situation. any help will be appreciated! cheers, Matt
