Kinda a novice question but non the less; With my decomp plate until i get a adjustable pulley its impossible to time the cinq perfectly, as it's half a tooth out unless i dont tension it properly... and i'd rather have it half a tooth retarded than half a tooth advanced,
My question though is which pulley needs to be retarded for the ignition to be retarded? Im guessing its the Crank as thats where the ECU gets its TDC reading? so in esscense when the cam pulley is timed up, the crank will be half a tooth away from lining up?
Does this sound about right?
Cheers,
Alex
Cheers,
Alex
