Can you point me in the direction of where to get replacements please?Yes .....lots...... on earlier multis but the arms are the same.
Thank you for your reply, i am in the midlands uk. It is just the passenger side that needs replacing bit was thinking i might as well do both.Where in country are you?
Best stuff to use is Plusgas, and plenty of it too. Haven't found anything as good, anywhere. (WD40 is NOT any good for this sort of thing, believe me!!)Are you doing the job yourself?
There are a couple of pitfalls to avoid.
Even if you getting someone else to do start spraying penetrating oil between the metal plates that clamp the radius arm in position and the radius arms. This will help removed the long bolt that goes through the bearings-which can be seized very tight.
Plus spray the all the bolts that hold the anti roll bar to radius arms.
