Technical Rear left abs sensor
sowyunix
Just replaced the sensor and i am getting the same message even if ive cleared them!? How can i check if the connector behind the whell is ok? And i whant to check all the way to the abs module! Any ideas?
Worth looking at the ring to see if its dirty, damaged, or split:
So the story is at the beginning I thought it was the abs pump , did a scan and error recived was no connection with rear left sensor, replaced the sensor but same error! Light is still on, my electician said it might be a split wire o so! But i do not have time to check it!
Ok so i said i will try to sort it out! I do have all the tools needed and basic training! But can anyone tell me the coloring codes for the wires!
Fiat stilo 1.9jtd 115bhp, Multiwagen, left hand drive
I do have abs scaner for fiatecu, multimeter, soldering gun! It kills me when i see that light on and i recon is a easy fix!
PS. All the sensor magnetic tape being cleaned...sane
Pic attached
