W wsty New member Joined Oct 19, 2005 Messages 24 Points 10 Location gloucester May 4, 2009 #1 sounds like a metallic rattle from OSF wheel area?? any ideas?? all help appreciated
custard Status: DEFCON Grumpy Written 10+ guides Uploaded 5 resources/downloads Joined Nov 4, 2003 Messages 48,609 Points 10,657 Location Edinburgh May 4, 2009 #2 i would be checking your springs not snapped or if you have it the spring catcher isnt loose
OP OP W wsty New member Joined Oct 19, 2005 Messages 24 Points 10 Location gloucester May 4, 2009 #3 spring seem to still be taut and when i push down on wing no noise at all.
D dan-the-man popping out Parked in the garage Joined Sep 24, 2005 Messages 3,215 Points 612 Location Kirkby in Ashfield May 4, 2009 #4 sounds like drop links, cheap to buy, a bugger to replace. They make rattling noises when going over rough ground.
OP OP W wsty New member Joined Oct 19, 2005 Messages 24 Points 10 Location gloucester May 4, 2009 #5 just had another look and looks like the spring may have snapped after all although no noticeable difference in driving, is that normal?? any idea of cost to replace??
D dan-the-man popping out Parked in the garage Joined Sep 24, 2005 Messages 3,215 Points 612 Location Kirkby in Ashfield May 4, 2009 #6 most people didn't know their spring has snapped. you'll need to replace both springs as you can't replace just one, no idea of cost of the springs, but labour shouldn't be too much.
OP OP W wsty New member Joined Oct 19, 2005 Messages 24 Points 10 Location gloucester May 4, 2009 #7 cheers dan
