Bennibs123
Hi all,
Recently the wife’s car started smoking on the way to work. After a quick look I could see the top rad pipe had burst. I replaced this then wanted to test the system.
Whilst testing I noticed after idling for maybe 10 minutes the rad was not kicking in? The tempreture gauge climbed to mid way no problem and stayed there. So it’s not overheating but at the same time the rad is not kicking in?
Bit confused with it , maybe could be the temp coolant sensor?
Checked the fuses and they’re okay. But I’m thinking if it was a fuse or relay then the engine would start overheating , but it doesn’t.
Not sure if there’s a way to test the rad manually?
Any help would be appreciated
Ben
Ben
