hi there everybody.
i need some help with the above mentioned as believe our overheating problem is connected.
i know where the thermostat is located on engine and have disconnected both pipes to it so far.there was one large bolt at bottom of unit that i have undone but have read that there is another?the only one i can see is a large nut with a sensor attached to it and a nut holding a wire on it.i have udone the nut and wire but am dubious about the nut with sensor? the bolt left attached to thermostat is laying inside a metal sleeve which is attched further down on engine.
now the large bolt is undone how do i proceed to remove the the unit?
any photos /help greatly appreciated
