Cento78
- Joined
- Jul 14, 2014
- Messages
- 39
- Points
- 6
Hi all, coil packs replaced, the plugs are not even sparking now! Took note what Fingers said about placement of the crank sensor, on my car, it's fixed by 2 screws on a solid bracket which appears to be part of the engine block, this looked ok when I checked it. Next step to check wiring from coils back to the ecu for 12volt power. Does anybody have a simple wiring diagram of the ignition circuit starting from the battery via the ignition switch and any relays and the ecu ending at the plugs? Because even though I have a Haynes manual, the wiring diagrams are not model specific and a bit complicated.
Regards
Bill
Regards
Bill
