Hello fellow Multimen/women.
My 07 multijet is driving me bonkers of late. Its got 80K on it and I get a repeated, intermittent engine warning light coming on. Using multiecuscan, I can determine that this is the EGR valve. or is it?? It can happen when idling in traffic or accelerating on the motorway. The alarm comes on as well as the engine management light and it then runs in safe mode. Strangely enough, if I turn the ignition off and restart the engine all is fine, no more safe mode, but the light remains on. But after a time (could be a hundred or five hundred miles) the light will no longer come on. Strange methinks.
I've taken the EGR off and cleaned it, in fact it was fairly new when I got the car to years ago having been replace by the previous owner. I've checked it whilst off with Multiecuscan and you can see it operating fine. Some times the error code tells me that there has been over boost pressure, as well as insufficient exhaust gas flow. So then, if the EGR is working fine, and this fault is intermittent, could it be a sensor fault, and if so which one?
Thanks for your help peeps.
