You're in luck, I have the same car and only changed the radiator myself about 4 weeks ago. I do have access to a lift however....
I'll try give a step by step for you.
1. Jack the car up and support with stands.
2. Drain the coolant from the system using the drain plug.
3. Remove both front wheels and then all the screws holding the wheel arch liner to the front bumper.
4. Remove screws from the front bumper in the wheel arch and underneath. Remove the bumper and disconnect fog lights, sensors etc.
5. Disconnect and unbolt the horn.
6. Remove both headlamps.
7. Next, I think you have to remove the crash bar. Held on with 8 big bolts, it's a bit heavy so be careful. Some small plastic trim around it too, that has to go.
8. You'll then see the intercooler, aircon radiator and behind all That, the coolant radiator. Disconnect both intercooler pipes and then remove the screws for the intercooler. Take it off.
9. Remove screws for the aircon radiator and move it aside. Don't disconnect the pipes as the gas it toxic and simply moving it carefully will prevent you having to recharge the system.
10. I think that's everything out of the way now. Just unclip the pipes from the radiator, unplug the fan and remove the two top mounts. It's a bit tight, but it should just come right out the front.
To refit, just do the opposite of above. Took me about 4 hours to do from start to finish. Be sure to bleed the cooling system too and check for leaks after.
Good luck,
Aido1196
