Kevinpanda
- Joined
- Feb 4, 2021
- Messages
- 15
- Points
- 2
Can anyone tell me if I fit a brand new ECU (Magneti morelli) are they self learning as in Plug & Play learning the IMMO code of first key on ?? any help would be appreciated
Hi,The ECU did goo on, coded by the car on first key turn, it did however give me code for clutch position not learnt and 2 'Manufaturer specific' codes, didnt however solve my initial problem, but it will do as a spare if my ECU goes bad, which is common with Fiat ECU,s it would need a dealer to sort the codes out but is still useable, I have previously used a 'virginised' ECU on my 2012 Panda and it was Plug & Play, no fault codes but then again the 2012 doesnt have clutch switch.
