Hello everyone,
I am currently gearing up for the 120,000km maintenance for my Fiat Panda 4x4 Wild (TA 85hp - 2019) that I bought recently, and I could use your collective wisdom to make sure I do not miss anything. There are a couple of things I would like to discuss, and I would appreciate your insights:
Checks and changes
As part of this scheduled maintenance, the shop will be performing the standard checks and changes recommended for this mileage, such as brake fluid, oil and oil filter change, and so forth. In addition to these routine tasks, I am planning to ask them to replace the timing chain and spark plugs. Beyond the fluid-related matters, I am also keen on understanding if there are other checks, parts or components that usually go hand-in-hand with a driving chain replacement. If there is a cost-effective way to tackle these together due to shared labor, I am all ears. The goal here is to avoid the disassembly of the engine over and over, and save on labor costs.
Oils
I am curious to know if changing the transmission and differential oils at this mileage is necessary, and if so which ones to use?
The owner's manual has provided the following guidance on the recommended oils:
Gearbox/Differential (*1700ml) *for 0.9 TwinAir Turbo
Petronas Tutela Transmission Technyx 75W-85 (API GL4)
Rear Differential(*620ml) *for 4x4
Petronas Tutela Transmission Cross 75W-85 (API GL5)
Transmission Idler Unit (PTU) (*390ml) *for 4x4
Petronas Tutela Transmission Multiaxle 75W-85 (API GL5)
Possible Issues
Finally, could you please share your insights on things I should be cautious about or specific items I should mention to the mechanic before they start working on the car? 4x4 Fiat Pandas, especially ones with the TA engine are a rare occurrence here. I want to ensure that the maintenance goes smoothly and does not result in any unexpected issues later.
Thank you for your advice in advance!
Checks and changes
Oils
Possible Issues
