Hello
In addition to my ongoing idle problem, I am also dealing with ABS failure.
-When I connected to the ABS ecu, I saw that the left rear speed sensor was not reading.
Regarding this situation, I first changed the positions of the left and right sensors.
When I attached the left sensor to the right side, I received data.
So the sensor is solid.
I couldn't get a signal from the left side.
I decided to check the cables.
Regarding this situation, I found and measured the pins of the cables going to the sensor.
The 2 cables reaching the pin from the ABS ecu socket are solid
Finally I decided to disassemble the ecu. I checked the ECU under a microscope. All solders are solid. Mosfets are solid.
The resistance values I get from the other sensor outputs are the same as the values I get from the left sensor output.
So the ecuda is solid )
In this case, all that remains is the part on the wheel.
and I think this part comes on the bearing.
Has anyone had problems with this before? Do you know the part code or the tools needed to disassemble it?
As an example, I added the photo I marked with an arrow.
