Yeti
My Multipla TD has a very odd problem. It's had it as long as I've had it - I haven't really used it yet!
When trying to start, it won't. Turn it as long as you like, until you give it some Easy Start, it just WILL not go.
When turning over by itself, the fuel pressure is reading BELOW what is 'requested' - this would be causing the injectors to not fire at all.
Once running, the car runs fine, and the fuel pressure reads normal!
I have changed lift pump, fuel filter, injection pump, fuel pressure regulator and the fuel pressure sensor - and not one has made any difference at all.
So, any suggestions? Has anyone seen this problem before? I can't keep using Easy Start to get it going every time!
Thanks.
Thanks.
