evening guys i got a big problem my car use to leak oil on my number 1 plug so i did the whole motor ove pistons rings and the head from top to bottom but its still doing the shame thing number 1 plug is still wet with oil wt can it be please
If it's oil in the cylinder? and you'v fitted a new head gasket? is it possible that it's a crack in the head or block into an oil way? try a compression check to see if that shows anything.
did a comp test and it all good did a complete head job all is new bottom all is new plus change the injector with feul rail bit still the same thing ??
