Boring paper work out of the way for now but been busy working/away.
Got a bit of time off so thought id crack on, thought i best make the most of the sunny weather.
Today's plan was to disassemble the front near side. Get the wheel, hub, strut, and calipers off.
Got the wheel off after ripping off part of the sideskirt and a few good kicks, swearing (this always seems to help) it came off.
Yeh its buggered. Going to get the other 3 put on a balancer and see if they are bent or hopefully aren't. If none of the others are badly bent i'll probably go on the hunt for another. If the front two are no good, then on the new project i might have the fronts as Superturismo's and the rears as Abarths. Drifting style.
What's left of the strontflex gearbox mount. The whole bracket was hanging off the gearbox anyway. No idea where the rest of the mount has gone.
The hub nut needed a little persuasion before it came off.
Removed the hub and driveshaft.
Then set about taking off what was left of the wishbone.
Sheared clean in half. Brand new wishbone. Bushes are still good on it though, even though they have a few bits shaved off them due to how the everything bent around them.
Thought it would be easier to remove both the doors to allow access in the car and more crap gotten rid of.
Removed the steering wheel and looked at the instruments. Was quite surprised.
Nearly indicated 80 standing still and over quater of a tank.
Removed the ARB and took off the wishbones. The bushes that attacth to the wishbone on the edges; one has had had it. Its split in two due to shearing metal.
The ARB doesnt look too bad though, doesnt seem to be bent.
Ripped the other wing off as well. Didnt even use a saw, just brute force.
Getting the heater matrix out wasnt a pretty afair. Didnt bother to remove then dash or any of the screws for it. It was smashed anyway due to the wing and the inlet mani hitting it.
4' steel bar and using it as a lever..... Soon the plastice gave up and we just ripped it out. Piece by piece.
Calipers still work, could even seen the mark the brake pad has made in the disc on the n/s.
Though i never uploaded any pictures, all the calipers were professionally rebuilt. So happy they all still work and visually nothing but superficial chips in the paint.
Front calipers are off and as you can see good use of draining bottles.
Already started buying myself some new parts for the rebuild. Got myself a 'new' CDA. It might be small but its a start.
Got a few other plans that will be different for the new car but depends on cost.
In the meantime ive built myself a slightly smaller car but still pretty quick.
Made myself a small to-do list of everything to take apart and in what order (roughly), whilst also keeping in mind what bits i need for the new project.
New shell will probably be in July i think. Gives me a month to get rid of the current shell and source some other bits for the new project.
Pirus
