Hi all
Question regarding heat siezed engine...according to garage (Sceinto 2001 S)
A straight steel pipe which connects to the rad house just before the split in the pipes to the rad. It has a o-ring on the left side
(standing infront of the vehicle )
seems to have poped out of a hole which is right above the oil filter housing/casing connected to the side of the block( or least that is what I can remember ).
The bracket holding the steel pipe in place connected to the block has snapped. The vehicle was lifted into the air and I could turn the cambelt's gears with my hands.
Also noticed the vehicle's oil level had not dropped and the oil was black but still enough according to the oil dipstick.
Is there anything else in spesific I should look at? Anyway what's the steel pipe for?
