Hi. I have a 2018 2.3L Ducato based campervan that I bought from new. Over a period of about 9 months I have had to call out a technician twice in response to "Check engine" light and associated Limp Mode. On the first callout the engineer read the fault code - EGR, tapped it with a screw driver, said the EGR valve was probably stuck, cleared the code and said carry on - it probably won't happen again. I explained to him that being of mature years I have always been a gentle driver and he suggested I drive it harder. Then last week during a 250 mile trip from home it happened again. Same symptons. Second engineer read the code, said it was the EGR, cleared the code and said consider having a garage either clean it or replace. vehicle drove 250 miles home at about 70mph mainly motorway with no loss of power, or smoke. I think there may be an underlying problem, possibly involving the EGR or DPF though I have seen no DPF warning light appear but the exhaust pipe has some soot on it - whether that is residual from earlier I dont know but I've cleaned it and I was thinking of driving it really hard in manual mode (it's Comfortmatic) on the motorway for about half an hour to see if at re-appears. As you can probably tell, I have limited technical knowledge or capability in this field area so am likely at some stage to be handing the van over for repair as the fault has appeared twice. In the meantime I would like some means of self recovery since clearing the fault code has restored the vehicle to normal drivability without a 3 hour roadside wait it may be prudent to be able to clear the code myself while deciding how to procede with a long term solution.
So can anyone recommend a cost effective reader that will clear the code that can be carried in the cab?
