Here we go then, a thread dedicated to my most recent Panda .
This is my second 4x4 but the first one I can actually use. To recap, I was tipped off about it a few weeks ago and after seeing its potential took posession 3 weeks ago.
It's not been used for 5 years but is in excellent condition and showing 54,000miles. I'm hoping that with a little effort it can be brought up to top condition so that I can attend a few gatherings with it this year. It's not my intention to modify it, other than a set of alloys, prefering to keep this one as a fine original example.
Here's a pic the day after I bought it so we all know what I'm starting from....
As you can see it's pretty good to start with, just as well as I don't have too much time to dedicate to this one.
After driving it home I felt that it was in fine condition mechanically, apart from a little pinking under load.
Interior is 99% excellent, just the plastic trims that hold the carpet at the door apertures and a cracked instrument panel screen to replace.
Bodywork is mostly rust and dent free. I can see very shallow dents in the front edge of the bonnet where people have pressed the bonnet shut instead of just dropping it :bang:, and the same thing next to the drivers door handle, also where someone has probably pushed on a half closed door. Rust is minimal at the bottom of the drivers door and should be easily saveable.
As always I started with a good clean up, followed by fitting of the alloys from the blue clx. They will be coming off again to be refurbised and have the white lettering re-done on the tyres but I was impatient to see how it looked . Better pictures later but here's one for now.....
Next up was an Mot. I checked it over myself first and, sadly, found a rust hole in the inner sill, right at the back in the usual place beside the spring hanger. A bit disappointed to have found it really as the rest of the underside is spectacularly good, but it's there so I'll just have to accept that I cannot say that this one has never been welded .
Only other fault was the front screenwash didn't work. As it had been stood for so long the fluid had turned to gunge in the bottom of the bottle, consequently blocking up the filter in the pump, so a good wash out with hot water soon had this fixed.
Sure enough, when it went in for mot on Monday it failed on the hole, but also the emissions were a little high. Now as it was pinking on the first journey home I think it probably needs tuning, so I may as well give it a full service while I'm at it.
That's it so far, I've already cut out the rust and made a repair piece which will be welded in by the garage who carried out the mot, I'm not set up for welding yet. Tomorrow I shall do the service then it's back for welding and retest early next week, just in time to tax it on 1st of March .
Some pics of the rusty area. I made the hole quite a bit bigger to make sure they'd be welding to very good metal. I also tried to copy the orginal body contours with the repair patch as I didn't want just a flat piece of plate slapped on there, but with no panel beating tools to speak of I have to put up with it still looking a little crude .
