Has anyone bought one of these and does it work?
I am using a cable.You are using a cable not a Bluetooth connection? Always use a cable
On this setup it supplies a elm327 it has an connector to connect to my notebook and the other end to one of the 6 connectors provided and the other end to he diagnostic socket to the right of the steering wheel in the the car, in the multiecuscan program on the notepad I have to set up a virtual com port, com port three and the software connects to this . I can then communicate with the various ecu.s in the car, the programme tells me which of the different connectors to use for the different ecu.s I want to communicate with. I did not know there was a way to use wifi to connect to the elm327. Of the 6 connectors provided I he only used two of them up to now and the have covered most of the ecus.I am using a cable.
