General Missing something?
Looks like this..
original unit is a bolt in place job.very simple.
IIRC its a 10mm nut/bolt to unhook the reverse cable.then the entire shaft assembly comes off.
if oyu want to go aftermarket then cut of the gearknob section to reveal the metal inner shaft inside.obviously above the reverse cable assembly.
you will either need an omp adapter or bodge.
or as i did just push down on the shaft to engage reverse
dunno, I dont think anyones ever done it
but im guessing you break the old one off, fill the new one with glue and stick it on the end of the shaft
mines staying like it is, so i dunno :confused:
Something I do know -
My old Cinq' Sporting had leather that was "shedding" little bits of the leather, if you buy a 2nd hand replacement make sure it is in mint condition.
