Matt Taylor
I have bought a Microscan 213 alarm system to fit to my mk2 punto. I am having great difficulty with some of the connections and need some advice.
1 Where is the best place to make a connect to the indicators?
The steering column connections and hazard switches seems to switch the negative. I am dammned if I can see where the cabes are that run to the actual lights. Again I cant seem to locate them on the passenger fuse box either!
2 I need to locate the ign switch to starter solenoid as well
There are a number of cables from the back of the ign switch and want to make sure that I dont cut into the wrong one. I am assuming that the cable will be the one that has power when the ign switch is in the start position.
I hope that someone can help as I now have 1/2 the insides of my car pulled out
Matt
Matt
Matt
Matt
