charlie1973
- Joined
- Sep 28, 2007
- Messages
- 3
- Points
- 1
can anyone help whrer can i find the 5 digit code to reset the ecu:bang:
i knocked the fuel cut off switch car would not start but had a spark in the plugs when i turned the fuel switch on had the fuel comming through but no spark from the plugs when turning the engine over when i turn on the ignition on the key code light gose off as normal but when you tunr the engine over the key code light flashes
You reset the ecu by disconnecting the battery for a few hours.
Hi
Fait punto 1.2
Can anyone help i have changed the ecu that bolts on to the carb with a second hand one from an other car
now i get the key code light coming on and car wont start a
Any ideas hoto fix or over come?????????????? HELP PLEASE
bri
