Hi.Hello Luca,
Try posting in English, it will be much easier to get an answer. You can use google translate or even an automatic translation available in some browsers.
No idea what year is your Punto from, but check here:
Search results for query: Natural Power
www.fiatforum.com
Forza metano!
Regards
i found the ducato one on emuleAs far as I know, that will be hard to find. I'm struggling to find the one for the Ducato since 3 years
What kind of information do you need?
The Natural Power versions were not available in the UK, they are the most popular in Italy, The Netherlands and Germany. So I assume those forums would be the best to look at.
anyway i need for the ac system can you help me?As far as I know, that will be hard to find. I'm struggling to find the one for the Ducato since 3 years
if you want, if you give me a contact i will sent you.As far as I know, that will be hard to find. I'm struggling to find the one for the Ducato since 3 years
i found the elearn of the grande punto but not for the punto of 2014 that has similar but different ac systems.I'm trying to avoid such places for security reasons. I think there was something on mhhauto, but never got a confirmation / invitation / whatever to finish the registration. And now I can't ever recover my password.
The AC system should be the same as on gasoline engines. Look at the ePER on the forum - it has all the part numbers.
If you'll find the eLearn module for the same year gasoline / diesel Punto, you'll have all the electrical diagrams + connections + other useful information (ie. torques). Probably except the methane fuel system. As for the Ducato, I know that on some eLearn modules (those available online at aftersales.fiat.com) the Natural Power version information were available, but they are not in the iso file available in the download section of the forum. You could try to check for the Punto. But I cannot find a working link anymore
i've done another post with the ac compressor problem, thank you very much for the link of ePER, very helpful and well doneI've sent you a private message
For the AC, I don't know how does it work in FIATs, but in my daily car the compressor needs AC pressure to start. The AC circuit contains gas + oil to cool down the compressor. So without the cooling the compressor would overheat rapidly. To avoid that, the pressure is needed.
You should be able to find the potential leaks with UV light.
Try to modify the thread title, someone with a 2014 Punto will be probably able to help you more precisely
