Technical M382 door locking system with remote
kivar20
Has anybody ever installed this M382 meta system door locking system with remote on their Stilos?
I just installed mine according to the instructions but it's not working. Every wire connected to the right pins and wired properly. Any ideas? (except change car :)
The car is a '02 1.6 5d Stilo.
Hello,
Is this system can bus compatible? Locking on stilo is controlled via the can bus. You need to make sure that meta system can support this.
Also it is likely that even if it does , it will need proxy alignment (synchronizing) with the rest of the car`s systems. This is done using multiecuscan and elm 327 cable or using the examiner at the official fiat workshops.
Please post more information about this system so that we could help you out. A picture of instruction manual or installation manual would be nice.
Thank you for the quick reply. I uploaded some pics from the instruction manual. Hope that helps. I think i need to check it with multiscan. I have it and the cables:)
Thank you for posting the manual pictures.
If I was in your place, I would try to scan the body computer using the multiecuscan and see whether it reports a new unit. This meta system should be recognized in can network. Please let us know your findings once you complete this.
Furthermore, there is some useful info in this thread, have a look:
The conclusion was, that sometimes even if the alarm manual is pointing to one set of wires, it does not necessarily mean they are the right ones :
https://www.fiatforum.com/stilo/233721-3901t-alarm-wiring-help-can-wire-location.html
I would like to know if this M382 door locking meta system is working for user kivar20.
I bought just the same one and I am kinda confused with the wiring diagram, especially I do not understand fig.8 (which wire is where) and I also think that there is a missing picture for fig.11; can anyone explain me those numbers per wire?!
Fiat Stilo 2002 jtd 3d 85kw
