Hi people, I wonder if you can help out with my 1.9JTD (fitted to a Sedici)
When the car is is the rev range 1500-2000 and particularly going uphill the car kangaroos. If it was a petrol engine you'd say it was a mis-fire. It's like somone is turning either the fuel or the electrics constantly on and off. It doesn't happen all the time, sometimes I take it out and it runs perfectly, other times and I'm shaken to bits. My local garage is being helpful (I've had DPF problems in the past - another LOOONG story), they've put the diagnostics on and it was saying "clutch depressed" when nowhere near the clutch. They've replaced the clutch switch thinking it might be the source of my problems but it's still exactly the same. The car runs fine at idle, it's just when it's moving.
Another thought, when I got the car back after having the work on the DPF done, there was a bolt missing that holds the 2 parts of the exhaust together. Could a slight leak on the exhaust cause the problems I am having?
Any ideas anyone?
Any ideas anyone?
