This has been discussed a lot, people mention that most are too large, so the low gas speed effects atomisation, BUT:
IF the injectors are just before the port, IE standard position then the gas speed is identical, as effectively it's the same as standard, the gain coming from removing the restrictions at the standard throttle body, shorter tuned length etc.
In fact the gas speed will be greater than before at full throttle .
I've even seen people use standard ECU and injectors as modern injection systems self correct/ self learn using lambda sensor to keep afr correct - although on modern cars this is fairly lean, so can be improved.
I saw one car, that was fitted with 38mm Kawasaki 600 ITBs, even passed MOT with no tuning.
The question is, wouldn't a big single body be just as beneficial, just a long intake length?
