- Joined
- May 26, 2011
- Messages
- 232
- Points
- 161
A couple of weeks ago there was a horrible irregular rattle coming from the accessory belt area. Worst on cold start up and gets quieter when the engine has warmed up (but never quite goes altogether).
Also, for the past couple of years the speed of engine turnover when starting has been sluggish.
So today I put it up on the ramps, took off the under engine cover and sure enough the noise was coming from this area.
Took the accessory belt off and started the engine...noise had gone...and the sluggish turnover speed was back to how I'd expect it to be.
Something here is causing the rattle and sluggish turnover.
The belt and tensioner are 2 years old and still good.
The steering pump turns freely (slight oil weep from here)
The alternator turns freely
The AC pump turns freely, but there is a very slight rattle from the pulley when bashed with a hand (clutch mechanism?)
The crankshaft pulley looks ok.
I'm missing something, baffled.
Any ideas on both counts much appreciated.
Ron
Ron
