Good evening guys!! What product do you recommend to replace CD changer and make the Connect Nav+ Ipod/USB compatible?? Please can you advise and send me step by step illustrations to install the product.
You may use xcarlink or some similar products to replace the changer. There's also an IPOD or USB version that you may use.
To install it, simply remove the radio, you can find a guide to do so on the guides section , make your way around with the cable (you may put it anywhere you want, most users put it in the upper glove compartment, but this will require some small drilling to make room for the cable), plug the connector on the cd changer socket (there's only one place it fits anyway), than you should be able to play songs on the IPOD, USB or AUX IN when selecting the proper input in the radio. To select it, pres SRC until you see stuff playing. XCARLINK only works on the CD Player input, and the option is only activated when the device is plugged in.
