MoHo Aidan
Hi All
Just joined after buying our second motorhome last week.
This is based on a 2017 130 BHP Ducato.
I have an issue causing the Engine Management light to come on, symptoms below:
Error code P158115 Oil Vapour Heater/Blow-by Heater
All fuses are good.
When code is erased, all may run fine for a while eg recently went 80 miles without recurrence. Other times 20 miles or even immediate recurrence when restarted.
Given it is intermittent, I’m thinking not likely to be a fault with the heater itself? Perhaps a dodgy connector somewhere?
I haven’t seen any reports of this fault on other posts.
Has anyone had similar problems or have suggestions on what steps to take?
Many thanks.
All fuses are good.
Many thanks.
